Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Thread: 1986 125m spotted, now at new home
  1. #31
    TrickShot's Avatar
    TrickShot is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Delaware County New York
    358
    I noticed the starter is black while the rest of the engine is silver, not sure if that is the orig starter for the machine, maybe from a 250sx? I'd be careful if/when you try to start via battery unless someone can confirm it is correct.
    Thanks for the links. I felt of the wires when I took the photos and they felt stiff. Not sure if they are or because was so fackin cold out so I will be checking them all out in days to come. I agree the coil isn't right. Starter appears correct though according to this photo.
  2. #32
    Mar 2007
    Texas
    5,045
    nice score! take your time cleaning it and getting it working and soon you will have one very nice trike that will last lots more years. Please, don't just try to do a basic clean and run it into the ground. this one desires to be restored to normal operation. that means, replacing cables, properly cleaning tank, full carb rebuild, new fluids, replace chain for new (old is probably very rusty) new tires, (have wheels blasted and repainted), nre fluids all around etc.. I am not saying a showroom, but riding restore. it will work so much better and last much longer. Don't get stupid with it. the plastics are not replaceable. no aftermarkets or meiers are available. so only rude it EZ and softly unless you wanna have broken parts for ever.
    ________________
    https://www.mikesatvfix.com
  3. #33
    Carthage NY 250r rules
    2,355
    Nice score. I was looking at one of these on my local craigslist a few months ago it was the frame,motor and frontend. I was going to put the motor in a 200x frame . I was thinking a 125 auto x would be cool.
    250r rules
  4. #34
    Jan 2014
    Massachusetts USA
    782
    Congrats on your score! PM me if it turns out you need a stator, I have a couple of spares. Also a spare electric starter.
    1985 Tri-Z 250
    1985 ATC250R
  5. #35
    2,355
    This is the one I was looking at.Click image for larger version.
    250r rules
  6. #36
    Feb 2013
    Brazil, Indiana
    728
    Atc300r, I seen that one ebay. If the guy would ship I would've bought it a long time ago lol
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
  7. #37
    TrickShot's Avatar
    Aug 2010
    358
    I picked up a 1987 trx 125 and thought with a little luck the seat and exhaust would be interchangeable. This is not the case. I did get the wheel situation figured out though. I used hubs and rims off a 200s on the rear. Then on the front instead wof trying to change out the hub, I mounted a tire on a rear rim from the 87 trx125. Fit is perfect. I hate split rims and tubes as well.
    Found this post from captainweezy searching around. Does anyone know if any other hubs or rims swap to a 86 Honda 125M? I got some tires for it now, but just wondering, because I'm not fan of split rims either. I have an old 87 Honda 200sx at another location an hour away I might try if anyone knows if that might work before I make the trip over.
  8. #38
    110 atc's Avatar
    110 atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    green bay
    238
    Trickshot, I know the 200sx hubs will work on the atc 125. You can also use 200x/300ex/400ex hubs. All of these use a 4 on 110 pattern. The stock 200s hubs with the 4 on 130 pattern will also slide right on.
    1982 110, 1982 Big Red, 1983 70 Christmas Special X2, 1983 185s, 1984 200s, 1984 200m, 1986 250r, 1987 125m, 1987 lt500r x2, 2003 Rincon, 2008 700xx, 2016 pioneer 1000-5
  9. #39
    TrickShot's Avatar
    Aug 2010
    358
    Quote Originally Posted by 110 atc View Post
    Awesome, exactly the info I was looking for, thanks man
  10. #40
    TrickShot's Avatar
    Aug 2010
    358
    Quote Originally Posted by Trike_crazy View Post
    Nice score! The 2nd gen 125m's are my favorite 3 wheelers. At the moment I have 2 86 and an 87.
    Attachment 227659
    Attachment 227660
    Kicking myself just a bit, I must have searched every 86 Honda 125M post today in search of this picture, because I remembered seeing it earlier. Just couldn't remember which thread it was in, and ended up being in my own thread..
    What hub and rims are you using here Trike_crazy?
  11. #41
    Feb 2013
    Brazil, Indiana
    728
    In that picture I was using 400ex wheels and hubs. The wheels have since been put on my dx225.
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1987 ATC125M
    1985 ATC250ES
  12. #42
    TrickShot's Avatar
    Aug 2010
    358
    Are there specific years that work or do all years work for the 300ex and 400ex hubs to swap onto the 86 125m.
  13. #43
    Feb 2013
    Brazil, Indiana
    728
    As far as I know they all can be used
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1987 ATC125M
    1985 ATC250ES
  14. #44
    2,355
    I think the only hubs that wont fit are the 85-86 250r and 350x bigger spline. I have a set of trx 300 2 wheel drive rear hubs on my 81 250r. Some years of the quadsport hubs fit aswell.
    250r rules
  15. #45
    Apr 2012
    USA
    4,129
    For the 400ex/300ex question, it can be boiled down to part numbers. Most likely the spine count/size didn't change but I haven't followed those models much.
    Part Number: 43120-HN1-A20
    1999-2014 TRX400EX - (aka all 400ex years used this same part)
    Part Number: 42410-HC0-000
    1987-1992 TRX250X
    1993-2004 TRX300EX
    1999-2001 TRX400EX (odd these are listed, but confirms there is little difference between this and the part above - could be further validated there is no difference in axle part number)
    I suspect all of the machines above work fine, below might be possible non-working unless someone can confirm it works on one of them.
    Part Number: 42410-HM3-900
    2005-2008 TRX300EX
    2009 TRX300X
    Part Number: 42410-HN6-A20
    2005-2008 TRX250EX
    2009-2014 TRX250X
    The last option is by FAR the cheapest... $40 per side. In-fact it is so cheap if this part works on any of our 3 wheelers, it should be the go to part to replace them unless you're trying to stick to OEM correct part. Used hubs generally go for $40+ per set.
