Results 1 to 14 of 14
Thread: Let's see them 125's!
    Nov 2017
    Southern Minnesota
    16
    Any 125s with rear suspension out there? Let's see your 125 projects!
    TrickShot's Avatar
    TrickShot is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Delaware County New York
    358
    Slowly getting my 86 going.
    Jan 2017
    Shawnigan Lake, BC
    53
    My almost stock 125m. Cleanest trike I own. No real plans to modify it, just a nice old stocker.
    Nov 2017
    New York
    3
    awesome, looking very cool
    Tionesta, PA
    5,747
    My brother's and my 1986 ATC125Ms.
    Carthage NY 250r rules
    2,355
    I wonder how well this 125 motor would fit in a 200x frame.
    Quote Originally Posted by GageWallin View Post
    250r rules
    2,355
    I would build it for trail riding something different. If I was going to build a 125 racer I would use a cr 125 motor.
    Quote Originally Posted by The Dude View Post
    It will bolt right in pretty much. If trying to make a suspended 125 class racer I'd start with a pit bike though they have double the hp
    250r rules
    Jun 2015
    stonecreek ohio usa
    654
    That's interesting dude, I wonder what a Daytona 190 would do in an s
    Jun 2015
    stonecreek ohio usa
    654
    Whoops my bad, I thought you meant a lay down motor
    Jun 2015
    stonecreek ohio usa
    654
    Sure would
    Nov 2017
    Southern Minnesota
    16
    Quote Originally Posted by atc300r View Post
    I have no idea, I'm new to trikes. I still have to experiment.
    Jul 2012
    Seattle, Washington
    1,543
    Here’s my old 125, yea it’s got factory rear suspension!
    https://youtu.be/XUjpstw2zts
    Jan 2013
    minnesota
    5,911
    ...and if you wanted to actually be unbeatable you should use a KX125 engine!
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    Jan 2014
    Massachusetts USA
    782
    Just for the record, the upright cylinder 125M engine will not bolt into a 200X, nor anything else with an engine based off of CB100/125 architecture, ie: any atc185/200. The rear crankcase mounts are significantly wider on the upright cylinder atc125, and the 87-88 trx125 which shared the same engine. Trust me, I tried.
    1985 Tri-Z 250
    1985 ATC250R
