Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 101
Thread: Project "Bandito" 90/110
  1. #31
    Dec 2010
    845
    Wow the fenders shape looks like new other than it needs a little paint lol
  2. #32
    May 2007
    Coshocton, Ohio
    1,815
    The paint will be next. I also finished my steel front fender and it too is ready for paint. I need to sandblast my headlight housing and all of the red parts will be ready to paint. I found some paint that was a very close match to the tank I'm using. I'm not going to paint the tank. The original paint is too nice to mess with.
    Appalachian American Racing
    the home of
  3. #33
    May 2007
    Coshocton, Ohio
    1,815
    New computer is driving me nuts. I'll try to post up some new pictures. I got some more goodies for it today.
    the home of
  4. #34
    May 2007
    Coshocton, Ohio
    1,815
    Got my forks today!
    the home of
  5. #35
    May 2007
    Coshocton, Ohio
    1,815
    Another pic. I likemy old puter better.
    the home of
  6. #36
    6,811
    Wow nice set of PCCC forks . Look like they will clean up really nice .
  7. #37
    May 2007
    Coshocton, Ohio
    1,815
    Here are a few more pics of the progress so far. I'm using my old computer. I still haven't fully figured out my new one. I can't post more than one pic at a time with it so far.
    Here is the front fender when I got it.
    the home of
  8. #38
    May 2007
    Coshocton, Ohio
    1,815
    Here it is in the repair stage.
    the home of
  9. #39
    May 2007
    Coshocton, Ohio
    1,815
    Here are some pics of the fenders in primer. They just need a final sanding and and paint at this point.
    the home of
  10. #40
    May 2007
    Coshocton, Ohio
    1,815
    I have most of the parts I need to start mocking this project up. I still need wheels and tires. I have some from a donor but they are not what I will be using on the final product. I have more pics to come. Stay tuned.
    the home of
  11. #41
    6,811
    Good stuff . I really like these threads and keep the pics comming .
  12. #42
    Ripley Tn
    1,363
    the fender repair is cool nice work gonna be a cool build
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
  13. #43
    Wisconsin
    78
    Looking Good!!!!!!!!!! Great find on the forks. Got a tap bit broken in the head up in the exhaust stud hole in my new project. NOT FUN. Its been to two machine shops this week no one can get it out. Gona be in the shop all day till it comes out. So much for a ride today.
  14. #44
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by Kickstand 1 View Post
    I have an almost fool proof way to remove broken studs without drilling or tapping and this eliminates the possibility of breaking off drill bits, easyouts and taps in the holes. I've even used this process to remove broken drill bits, easyouts and taps that have been broken off trying repair broken studs and bolts.
    I use a mig welder to build up enough material so that I can get a good bite on it with a Good pair of vice-grips. As soon as I get it built up I put the vice-grips on it and start turning them back and forth. You sometimes have to start in very small l increments until the bolt or whatever starts to move more freely. I've had the weld break off many times until I finally got it moving. Over the years I have a success rate of over 99%. The heat from the weld loosens up the bolt, stud or whatever enough to get it out. I've even removed taps, etc. that were broken off below the surface.
    the home of
  15. #45
    Wisconsin
    78
    Ya no luck today. I will try that on Tuesday thank you for the info. This motor is fresh and have a lot of $$$$ in it. I was only cleaning the threads and it snapped. Thanks again for the info thats all i got left to try at this point.
