Results 1 to 15 of 25
Thread: atc 70 bolt on rear disk brake?
    May 2011
    eden,ny
    3,481
    does anyone know of one being offered now? or would ther be any interest if there was a kit available? I looked and all I could find were modified drums and some way too much fab work for a bolt on type of guy. Thanks in advance for any input.
    remsandpets's Avatar
    remsandpets is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2012
    Southwest, PA
    368
    That would be a nice addition. I would consider that a good mod if it were affordable that is.
    Russ J in SW PA
    83 Honda 200 (fishing and hunting "rig")
    83 Honda 185 (parts)
    95 Polaris Xplorer 300 4x4 (WIP)
    NC
    907
    Quote Originally Posted by remsandpets View Post
    Agreed. Would be nice to have, price would be key.
    Mar 2005
    overton, PA
    5,257
    hmmmmmm i have an idea hehehehehe le tme do soem research on this.
    May 2011
    eden,ny
    3,481
    what is affordable to you? Understand it will be a few off the shelf parts and some custom parts. @brapp no need to find the parts and design a bolt on caliper mount, I already did.
    Nov 2004
    Waterloo IL
    2,701
    Is there much need for it? The stock shoes fit bigger 3-wheelers and some motorcycles so its kind of overkill for a 70. With a nice drum and new shoes Mine will lock up the rear wheels with ease on hard packed dirt with me on it (210lbs). I'd say it might even lock the tires up on the road but I've never tried it. I'm not saying a rear disc wouldn't be nice, just not something I personally would spend money on.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Nov 2007
    ulysses pa
    1,231
    Quote Originally Posted by just ben View Post
    sounds cool Ben, lets see it.
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by Blown 331 View Post
    do I really need to explain the advantages? Less fade,better wet performance,no adjusting. longer pad life. You said the key words "with a nice drum and new shoes" These machines are 27+ years old and finding a brake drum that is actually not past its recomended wear can be difficult. If someone has an all original 70 this obviously wouldn't be for them but it seems alot of the 70's have been modified with bigger engines ect. and a modern brake system may be benificial to these modded machines.
    Isn't there a company that already sells a disc set up for a 70???
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by big specht View Post
    I have seen one for the front but it is not bolt on at all and having first hand experiance with it I wouldn't recommend it. That kit is just a couple pieces of steel tubing with a bicycle rotor. The rear kit I have in mind is all atv parts that are modified and a custom bolt on caliper mount
    Mar 2005
    overton, PA
    5,257
    well i found a rotor hub, that works with the stock axle, i located a source for a mechanical caliper for a foot brake , and now just need to find a rotor that works witht he hub as the one that works with the hub it 8 inches and a little bigger than i would liek on a 70, and also lookign up ideas for a front brake system also.
    Nov 2007
    ulysses pa
    1,231
    dude, you gotta quit holding out on us! lets see it,, im just pulled my 70 stuff out last night to start rebuilding it. i could be the first tester.
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    200x disc might fit, i know it fits the splines on a 90
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by trizilla View Post
    Your the only one who wants to see it lol. sorry I already have someone in mind to test it...me haha. The one in this picture is a bolt on but I had to drill two holes in the frame, The design I have in mind will be completly bolt on no drilling,welding,ect. There just doesnt seem to be enough interest to justify my time and money to put several together right now. I may put a kit together and throw it up on ebay to see what kind of interest there is out there.Click image for larger version.
Name:	70 brake 002.jpg
    Nov 2007
    ulysses pa
    1,231
    are you using a hand brake? i have been hording a working caliper, line, and master from a chinese quad but it will be hand operated. not a big deal to me but might be to some. how is your caliper mounted? caliper mount to frame? i cant tell from the pics. have you talked to jsmay? he's putting a couple 70's together and may be interested also.
    since you'll be testing this one can we expect to see you with this at the next race? maybe a 70 showdown?lol
