Results 16 to 30 of 65
Thread: My 1st Trike! 1982 Honda 250R Mega Pics and Videos
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Started some disassemby and some painting some parts, etc. Cleaned up the frame a little. Straightened the rear rack mount and then welded the bend for strength. Welded the standoff as well as creating one using a nut with the same bolt thread size and pitch.
ID:	200691Click image for larger version.
ID:	200692Click image for larger version.
ID:	200693Click image for larger version.
ID:	200694Click image for larger version.
ID:	200695Click image for larger version.
ID:	200696Click image for larger version.
ID:	200697Click image for larger version.
ID:	200698Click image for larger version.
    Nov 2012
    Waldoboro, maine
    791
    While you have your pipe off you should look in the exhaust port and give a little visual inspection of your piston and cylinder walls.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Bren_downe View Post
    Good idea. Will do!
    Leo
    MPDano's Avatar
    Sep 2014
    Got the total hookup from Paul of San Diego. Glad to have a local ATC guy here. Got a Tank/Cap/Petcock, Rear Fender, Cooler Rack, Carb Choke Assembly and misc nuts n bolts for a killer deal.
    As soon as I got home, I mounted up the tank (looks normal now) and painted the weld areas with some Rustoleum Sunrise Red Rattle Can Paint.
ID:	200772Click image for larger version.
ID:	200773Click image for larger version.
ID:	200774Click image for larger version.
ID:	200775Click image for larger version.
ID:	200776Click image for larger version.
ID:	200777Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Rebuilt the Carb after work and installed the new Choke assembly. Man removing the broken Choke Assembly was a pain. Carb soaked in Berrymans for a couple days, love that stuff. Anyways, Air Filter Box reinstalled as well as Rebuilt Carb.
    Pic is a 155 Main Jet that was in the old and the new one that was in the kit is 150, which is the one I installed.
    Also, ordered some Red ODI Mushroom Grips (love em from back in my BMX days) and a Uni Filter.
ID:	200813Click image for larger version.
ID:	200814Click image for larger version.
ID:	200815Click image for larger version.
    Sep 2011
    Ocean Beach, CA
    1,333
    I would advise you to keep the 155. It was likely installed by the previous owner who rode in sand. Your motor only has the fuel it burns and the air traveling over it to cool it. Sand will rob power, overheat, and melt down an air cooled 2 stroke motor in minutes if not jetted properly. Yes, 150 was the stock size, and you dont have any 'high flow' mods that would require a larger main, but for the dunes, fat is safe, and safe gets your bike through the entire weekend. youre not gonna win any drag races up test hill with that thing, so just getting it to live is your main goal. It will probably run just fine with the 150 at Corral Canyon or Pine Valley, but take it to Gordon's or Superstition and it will run hot. Jet for the long haul. Improper jetting gets expensive, real fast.
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by manbearpig View Post
    Great point. Thanks for posting this. I'll switch jets asap!
    Leo
    MPDano's Avatar
    Sep 2014
    Bought new taillight bulbs (part # 34902-259-000) and spark plugs (NGK B8ES)
    Painted the Exhaust Pipe and Silencer with flat black header paint. Reveived the Odyssey Exhaust sealing metal ring and gasket, will chime back on fitment.
    Jun 2009
    Leander TX
    2,217
    Great thread. Excellent 82!
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by jb2wheels View Post
    Thanks! Trying to keep the thread useful for others as well.
    MPDano's Avatar
    Sep 2014
    Exhaust reinstalled. The Odyssey metal Ring and Gasket were too large. Weird that my 79 Odyssey had a larger exhaust and motor is the same one. Anyways, my metal ring on the ATC was fine, so I cut down the paper ring (looked almost like cardboard) and installed it. Hooked up my Tank and put some 32:1 gas in and fired it up. Put the old Fender/Seat on and drove around my yard again. Can't wait to get this all together and on the local trails.
ID:	200900Click image for larger version.
ID:	200902Click image for larger version.
ID:	200904Click image for larger version.
ID:	200903Click image for larger version.
    MPDano's Avatar
    Sep 2014
    Removed the rust off the Cooler Rack and polished it up and hit it with some Clear Coat. Polished up the Shock and Canister and also put clear on it. Removed as much rust off the Seat Pan and put some black paint to keep the rust in control. Going to install the new Seat Cover at some point over this weekend.
ID:	200982Click image for larger version.
ID:	200987Click image for larger version.
ID:	200992Click image for larger version.
ID:	200991Click image for larger version.
ID:	200990Click image for larger version.
ID:	200989Click image for larger version.
ID:	200988Click image for larger version.
ID:	200983Click image for larger version.
ID:	200984Click image for larger version.
ID:	200986Click image for larger version.
ID:	200985Click image for larger version.
ID:	200997Click image for larger version.
ID:	200996Click image for larger version.
ID:	200995Click image for larger version.
ID:	200994Click image for larger version.
    Sep 2011
    Ocean Beach, CA
    1,333
    dont forget to oil that filter. best to do before installation to get the best coverage. lookin good!
    MPDano's Avatar
    Sep 2014
    Thanks Man, but I did already. I always use my K&N oil on my toys. Got that covered. Thanks for the compliment. Working on the seat foam now, hope to get it on the trike tomorrow.
  15. #30
    MPDano's Avatar
    Sep 2014
    Fixed my Seat Foam, installed the new seat cover and installed the Rear Fender. Installed the Skid Plate and gave another test ride in the backyard. This toy is so much fun.
ID:	201103Click image for larger version.
ID:	201107Click image for larger version.
ID:	201111Click image for larger version.
ID:	201110Click image for larger version.
ID:	201109Click image for larger version.
ID:	201108Click image for larger version.
ID:	201117Click image for larger version.
ID:	201116Click image for larger version.
ID:	201115Click image for larger version.
ID:	201114Click image for larger version.
ID:	201113Click image for larger version.
ID:	201112Click image for larger version.
ID:	201118Click image for larger version.
ID:	201106Click image for larger version.
ID:	201105Click image for larger version.
ID:	201104Click image for larger version.
ID:	201121Click image for larger version.
ID:	201120Click image for larger version.
