Results 46 to 60 of 65
Thread: My 1st Trike! 1982 Honda 250R Mega Pics and Videos
  1. #46
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Quote Originally Posted by czac View Post
    I just did my rear tires, take the core out of the valve stem and then air up the tire till the beads pop. I only have a little craftsman pancake compressor and it popped the beads on no problems. I used a blow gun to air the tires... a regular chuck wont work without the core in the valve. the little air gun or blow gun that came with the compressor has a rubber tip on it that's cone shaped so it fit in the tire valve stem... But, if worse comes to worse, try the starting fluid method, I used that on a trailer rim...lol scary but it works! check it out on YouTube! just be careful and remember to first REMOVE THE VALVE STEM CORE! https://www.youtube.com/watch?v=N45KcCsBYmc
    Yeah, I was thinking about the starter fluid seal, but that didn't work for me on the Odyssey. I don't much like things that explode and the funny thing is that I am an Army Veteran too.
  2. #47
    Nov 2013
    Oxford CT, New Haven County
    984
    no? worked like a charm for my trailer tire. Hmmmmm... how about finding a more powerful compressor, crank it to like 150 PSI and let her rip?
  3. #48
    MPDano's Avatar
    Sep 2014
    Thanks man. I've tried every which yesterday. Yup, I always remove the valve stem. I have a 25 gallon compressor too. The wheels are in my truck now, so I will get the local MX shop to do it.
  4. #49
    Slidell, LA
    4,738
    you don't need much air to pop the beads. I turn my regulator down to 30 PSI when popping ATV tire beads. Make sure you lube the outter/inner lips on the wheel (I use dawn dish soap). The tires usually pop around 25.
  5. #50
    Nov 2013
    984
    well, no ones gonna fault you for not trying..lol they should be able to pop em right for ya! good luck!
  6. #51
    MPDano's Avatar
    Sep 2014
    I normally lube up the tire bead area and that usually works for me. I was thinking about the rim as well after the fact, but already loaded up the wheels in my truck.
  7. #52
    MPDano's Avatar
    Sep 2014
    Well the project is now on hold. Two bad tires. Ughhh.
    This sucks
  8. #53
    MPDano's Avatar
    Sep 2014
    maybe I'll just buy two tubes with metal valves as I did the same thing with my mini-buggy and it holds up fine. Tires have great tread and hate to just ditch them. Choices choices.
  9. #54
    Feb 2014
    Victoria,Australia
    878
    Quote Originally Posted by MPDano View Post
    This sucks
    don't put tubes in your tyres especially since its such a high powered ATC!! just get some new tyres...
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
  10. #55
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by jakep53 View Post
    Sorry Jake, couldn't afford the new tires so went with some tubes I got at the local MX Shop. They got the steel valves on them too. The tubes are pretty beefy so I am not worried about it. Pics are taken at night when I finally got them all together and mounted. Will take final shots during the daylight. Going to try and get out this weekend and give it a good test ride.
ID:	201917Click image for larger version.
ID:	201918Click image for larger version.
ID:	201919Click image for larger version.
  11. #56
    MPDano's Avatar
    Sep 2014
    I installed my new Acerbis Hand Guards today, I shortened my levers as I had to do the same thing on my KTM Dirtbike. Installed the lever sleeves and Handlebar Crossbar Pad. I love this trike, took it for a quick spin around my backyard then snapped some pics. Last thing to do is to put my Registration Decal and I am ready for the local trails this weekend. Bring it!!
ID:	201957Click image for larger version.
ID:	201958Click image for larger version.
ID:	201962Click image for larger version.
ID:	201959Click image for larger version.
ID:	201961Click image for larger version.
ID:	201960Click image for larger version.
ID:	201966Click image for larger version.
ID:	201967Click image for larger version.
ID:	201968Click image for larger version.
ID:	201969Click image for larger version.
ID:	201970Click image for larger version.
ID:	201971Click image for larger version.
ID:	201972Click image for larger version.
ID:	201976Click image for larger version.
ID:	201974Click image for larger version.
ID:	201975Click image for larger version.
ID:	201973Click image for larger version.
ID:	201977Click image for larger version.
ID:	201963Click image for larger version.
ID:	201965Click image for larger version.
ID:	201964Click image for larger version.
ID:	201978Click image for larger version.
  12. #57
    mesquite tx
    12
    Looks awesome! Getting some ideas for a refresh on mine.
  13. #58
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by perryc View Post
    Thanks Perry!
  14. #59
    MPDano's Avatar
    Sep 2014
    My test video taken at McCain Valley with my family.
  15. #60
    MPDano's Avatar
    Sep 2014
    Registration Decal installed and legal eagle till 2016. Loaded up the 3 Reds and headed to McCain Valley. My 7 year old sons 70cc kept getting stuck in the softer sand areas, so I put him on my wifes 90cc and he rocked it.
ID:	202104Click image for larger version.
ID:	202105Click image for larger version.
ID:	202106Click image for larger version.
ID:	202107Click image for larger version.
ID:	202108Click image for larger version.
ID:	202109Click image for larger version.
ID:	202110Click image for larger version.
