Soooo. I am having two/three major problems with this three wheeler and I’m hoping that I can get some good help.
When I was taking the exhaust apart one of the bolts that bolt the front of the exhaust to the motor snapped in half. This bolt is reverse threaded into the front of the motor, correct? I have tried to get it out with vise grips but it didn’t budge. Any suggestions??
I would assume that I would have to take the motor out so that I can get a better grip on it. If that doesn’t work then I suppose I would get a shop to drill it out and re-tap it.
If I take the motor out, I come to my second problem, the shaft drive. To get the motor out I need to detach the shaft drive from the motor. How do I do this? Do I need to take the pivot bolt out, rear shock, rear wheels, etc.? I am stumped.
If I do need to take the swing arm out to remove the motor, any suggestions on how to get the pivot bolt out? That bolt is stubborn.
