Results 1 to 15 of 20
Thread: Anyone Else Bench Run a Motor?
    Cold Lake, Alberta, Canada
    3,016
    Since I find it a pain in the azz to get the US90 motor in and out of a frame, I thought I'd bench test a motor that was part of a basket case trike I bought. I made a crude bracket to secure the coil to the case and blocked the engine up on my lift table. Not pretty but it worked. This motor was said to have potential tranny issues. The good; the motor purrs like a kitten, the bad; no 'Hi' range and you have to sometimes shift twice, up or down to change gears. I don't know if that's because it's been sitting so long or what. My spider senses are telling me the tranny has issues. I have another engine for this project (also questionable) so I have options. Think the tranny is worth looking into?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    andersonee4's Avatar
    andersonee4 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ames, Ia
    169
    Thought of it before. But way too much wiring and confusion for me. Glad it worked for you
    1985 Honda 250sx. Ground up rebuild. SOLD
    1986 Honda 250es Big Red with custom plow
    Don't waste your time, or time will waste you.
    3,016
    Quote Originally Posted by andersonee4 View Post
    Two wires only. Just had to look over the wiring diagram; that's important. No kill switch but the choke will do the same.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Dec 2010
    washington state
    681
    thats a good idea , those 90/110/125 seem harder to switch then the bigger ones ,wish i had tested mine before mounting the 125 up, it runs great but same problem dont shift right so its gotta come back out , hopefully its just the shift forks or something easy lol ,not sure but the high,low is seperate from the main trans so that may be easy fix ,between the 2 you should be able to make one good one, least you saved youself the hassle of in,out, back in, gonna tackle that 125 again next weekend
    GOT MUD?:
    Pacific NW
    4,255
    Quote Originally Posted by 350XJEDI View Post
    Hey coolpool, I've had the 90-110 hi lo shifters be really rusty stuck and took some convincing to get them to go all the way into and out of hi and lo.
    jedi? The 125 has common issues with the 'shift drum stopper' bolt coming loose,
    Acts like a real mystery shifter. Tap once or twice to change gears. Maybe 3 times.
    EZ fix, I rolled the trike on it's side, took off the clutch side cover and there it was.
    Can't seem to upload pix at the moment. Sorry.
    My final oddity was a 90 that the guy took the hi lo gears out of and handed them to me but it still
    ran/shifted fine.
    He must've left one of them in there.
    Dec 2010
    washington state
    681
    thanks that sounds like what its doing ,will check it out , glad i dont have to take the moter all out again , what a pain ! the kids will be happy ,if i get it working .. how would the 90 run if the hi/low gears are out ?? I want to do a clutch conversion on my 90 one of these days . I read a couple threads about it , sounds good need a sl 90 moter for parts i think ? gotta do more research on it !! my 125 and 90 both have pppc front forks , love to get a custum susp. frame for the 90 ,$$ or lucky score
    GOT MUD?:
    Pacific NW
    4,255
    wow. most excellent.
    I'm lucky if I can just keep anything going.
    yeah, that 'shift drum stopper' mounting bolt is what I found in the search key.
    I also posted pix last summer when I did it so they have to be on here somewhere.
    Search key 125m shift drum stopper? maybe?
    I had the luxury of a 110 parts motor for autopsy and when I took the side cover off
    (engine was normal vertical position)
    I started touching all the cool levers and cams and wobbly washers with the ball bearings
    and since they simply sit there, they came off easily in my hands and I had NO idea how to put it back together.
    so when I finally got to the 125, I laid it flat *&^% on it's side so nothing would move.
    took pictures and then took stuff off ONE at a time and put it back on and so on.
    I'll retry pix tomorrow but bet they come up with the search key.
    Wa state?
    ever been to oregon country fair?
    Dec 2010
    washington state
    681
    yup been to or fair yrs ago ,not really my scene ,I'm in vancouver ,, you in OR ?
    GOT MUD?:
    Pacific NW
    4,255
    Yupp.
    Not my scene either but we do a massive music festival around the same time.
    3 days of food and music.
    Of course, a 12 pack of assault trikes to putt around on for our security team.
    At least thats my excuse for collecting them.
    I'm looking at some sort of dunes meeting mentioned in another thread,
    Never been to Coos to rride but I know Florence is simply gorgeous and huge.
    It would take days to run all the trails.
    Yeah, top bet is your shift drum stopper mounting bolt came loose or got bent.
    Worst case is the stopper lever itself is avail everywhere and is like 10 bucks.
    I had 6 pages of pix to choose from here in my stash at 3ww but I can't seem to access
    any.
    Maybe tomorrow.
    Yeah, my 125m runs great but is kinda unfixable because the standoff in the case casting broke off
    where the bolt screw in to hold the shift drum stopper.
    Someone must;'ve beat the daylights out of it and kept going..
    It was 100$ with 3 good tires so I can't complain. Non busted plastics but no seat.
    I hate parting trikes out but this one may qualify.
    or I could drop in a 110 but I already have 4 or 5 - 90/110's
    and the weather sucks for working tediously outside with freezing tools.
    Time to ride and huge bonfires and burn the leftover christmas trees and stuff like that.
    edit
    FOUND IT!!!
    http://www.3wheelerworld.com/showthr...t+drum+stopper
    Attached Thumbnails Attached Thumbnails clutchside1.jpg   clutchUNbrokeboss3.jpg   clutchbrkenboss8.jpg
    NEPA
    7,051
    Interesting Pete.. I am curious how much it vibrated! At school,,we had to bench run ALL our motors ,which were ALL Briggs and Tecumsehs.. Fast forward 12 years.. My Dairy farmer neighbors with self propelled silage carts started bringing me in these 5.5 HP Honda engines.. They lived absolutely thankless lives. Yank the cord Morning ,noon and night 365 days a year. Check the oil ? maybe once in a great while.. Anyhow,,the breather boot would rip from heat and the rot of the silage. Which would burn the valve stems.. ANYHOW! The 1st time,,and every time after! I benched one of them ,I would just stand there in total amazement!! They would start up,and just sit there idling.. NO clamps! At school?? Those briggs and Tecumsehs would run away from you the entire way down the bench without a MINIMUM of 2 or 3 clamps! I was always a Honda guy. But to see this 1st hand without prethinking it always blew my mind!! That's my bench story! I have never done it with a motorcycle/atv/sled though.
    3,016
    I was a little nervous at first about the vibrations but was totally amazed at how smooth it was. I never did go much above idle since this was just to see how it ran and shifted.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    na
    5,702
    The Alabama Gang have a 90 engine mounted on a trailer they tow behind a 110 hooked to a beer keg for a Margarita machine..So I would consider that "bench testing"..LOL
    Proudly NOT a member of
    "Team on the Teat"
    Dec 2009
    BFE
    1,202
    I wanted to but I couldn't get my leg lifted up high enought to start my 350x motor when it was on the work bench
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    NEPA
    7,051
    A beer keg and a margarita maker ,,Behind a kids 3 wheeler,,,,,not exactly WHERE I saw this thread going???.. We sure do have Different uses for our beloved machines !
    web3wheels's Avatar
    web3wheels is offline At The Back Of The Pack Arm chair racerFirst time rider
    st. louis
    221
    cool - i had a couple motors that have been sitting for a long time. seemed like the gears were shot. someone told me they had the same issues with their 90 motors. he said they just need oil and you have manually move the shifter and sub trans lever back and forth a bunch to bring them back to life. seems to work for me. one of my sub trans wouldnt shift and after riding it a few times it finally did. it was a huge relief. when i was young i had a 125 new. i remember shifting the sub trans while the bike was in gear but now for my 90's i have to stop, put it in neutral and rock the bike back and forth and its still a little tricky. dont know if thats exactly what you are describing but dont give up. i think alot of people have trouble with these sub transmissions. they wind up opening them up and screwing them up more. i got a bike once that was missing pieces inside there, and i know another guy that had the same issue. get out a diagram or open both of your motors side by side and make sure you have all the bearings and gears too.
    SIX US90s & a few aftermarket parts ;-)
    my feedback http://www.3wheelerworld.com/showthr...for-web3wheels
