2011 Rule draft.
Trike Fest 2011 Drag Rules.
Saturday, the 25th @ 11:00AM grudge racing & Inspections begin. Actual racing starts at 1:00PM the absolute latest. Would much rather prefer to start around 12:00N We still have to do a group picture, and the awards banquet Saturday night.
In the years past we've had several different members do the drag races. TimSr in the early days, Rick and Dawn later on, and then Roger & Raffa in the most recent past few years.
This year, I'll be heading it up. I've got Xowner enlisted to help me, and I think Raffa will still be helping. Anyone that has previous experience and willing to help
out is encouraged to get with me. We are going to need help with the sign ups, the tech inspections, and also the brackets. Probably 6-8 people so if your available please let me know.
That being said, after reviewing the rules that Roger and Raffa have had in place for a few years now I've decided to basically just go with the same thing minus a few tweaks to try and keep everything consistent for everyone. My theory is that these rules are for the most party already pretty familiarized, and people that had their bikes setup last year should be in the same classes this go around as they were. Most of you should already be familiar with these rules, but for those that are not, here they are:
***Starting System***
We will now be using a Green light - Red light red is staging.. you will be pointed too to make sure you are ready..a simple nod of the helmet,,will tell us your ready.. when the red light turns green GO!!!! (DO NOT CREEP OR JUMP THE LINE! THERE IS A DELAY WHEN SWITCHING OFF AND THE GREEN COMES ON, WAIT FOR GREEN!) Finish line will be decided by 2 people on each side of the Finish line and a arm raise on that side of the track will tell the winner..and or a walkie talkie..
*** RED LIGHTS*** Red Lights will be counted as a LOSS.. obviously a 1/4,1/2 bike is a loss ..you will know it and the staging personnel will see it..staging person will be watching each start and its his or hers (Call) on the red light under 1/4 bike.. best bet .. wait till it turns green..
***If final win cannot be decide by either sides at the finish line a RE-RUN will be called... Re-runs are called at my other staging volunteer's discretion. If its too close, your re-running.
***All final lane choices will determined by wins and losses.If tie a coin will be flipped..
1.Youth class
2.stock class
3. modified class
4.open class
Rules.
1. Youth..
A. trike or quad under 125cc
B.must be 12yrs old or younger
C. conversions or Hybrids OK
D. machines will be paired as close as possible
2. Stock Class.
STRUCTURE....
A.49cc-174cc
B.175cc-250cc
C.251cc-351cc 4 stroke
D.250cc 2 stroke
2 -Stock.
-Trikes only
-exhaust, must be ran in the way manufacture of your machine designed it.
(aftermarket pipes are allowed if ran in this manor)( No out of frames)
- frame must be to factory spec. (no frame mod's)
- Engine must be the original, OEM equipped one. No aftermarket or different then originally equipped cylinders for 2 strokes or 4 strokes.
Any internal engine modifications allowed. 2 strokes are allowed to run aftermarket/non OEM cylinder heads. 4 strokes are not.
-No hybrids, conversions or engine swaps. Machine must be an original OEM three-wheeler.
-swing arm's, can be stock length or up to +4" extended ( will be approved by a tec)
- Gas, must be on pump gas (no more than 98 octane) Aftermarket carbs, clamp-on airfilters, etc all allowed.
No race fuel or oxygenated fuels! (This will be given the smell test, if you fail your going to the modified class, sorry!)
- tires, stock or aftermarket... No studs!
-No wheelie bars
-aftermarket axle's OK
-we will try to pair up same bikes in the first round,or close too. 250r v.s. tri z ,,200x v.s. 200x
-ALSO, --NEW FOR 2011-- Highly modified mini's with larger displacement engines (150cc piranha engines in ATC70s, etc) will be ran in the class most appropriate for their CURRENT engine displacement. This means unless your over 174cc you will run in the 49-174cc Stock class. I understand this isn't an ideal situation but I do not believe there to be enough entrants to make a whole new class at this time. Perhaps next year.
3. Modified class.
-OEM trikes only
- any bike that has been modified Carb,bore,aftermarket cylinders,Big bores,long rods. NO engine swaps, or hybrids.
-swing arms, can be any length.
-wheelie bars, you can run a wheelie bar
-NO ALKY or NITROUS
-exhaust,pipe in or out of frame ok
-Studs permitted,must be ice screws,No picks,bolt tires,ect,atv use only.
-Basically created for the powervalved,big bore..300,310,330, stroker,ect.
-If you don't think you have what it takes to run with the big dogs in the open class..this is for you.
********At tec's discretion, if your bike don't fit the requirements of the class, you may be bumped to the open class in the interest of fairness to other competitors
4.open class.
- Trikes only
-All motorcycle or alternately based/customized machines.
-drag pipes or any custom. ok
-hybrid,conversions..ok
-swing arm, any length
-wheelie bars,ok, please use best judgment on building these. any loose bars will be asked to
tighten them up,before running. there for helping you not flip,not causing you to flip.
-fuel, Any fuel,race gas,alcohol,Nitrous oxide, all ok
-Tires,any tires
-studs, ok must be for atv use, (Ice screws),no picks
NOTE:
--NEW for 2011-- We are going to for the first time ever going to attempt a pre-sign up on FRIDAY EVENING!!!!!!!!!!! You MUST MUST MUST MUST register FRIDAY EVENING. Meet at the drag strip approximately a half hour after the end of the motocross races. This gives us adequate time to lay out the brackets and double check everything. Barring rain or some unforeseen circumstances, We WILL NOT ALLOW SATURDAY SIGNUPS!!!** If your not arriving until Saturday or late Friday night, please contact me PRIOR to Trikefest so that we can make arrangements for you and get you counted ahead of time.**
--NEW for 2011-- Tech inspection will be starting @ 11:00AM Saturday morning. Racing to begin immediately following completion of tech inspection on all machines that pre-registered Friday night.
When your number has been called ,the racer will have a set time to make it to the start line for heat race or be DQ'ed from that round.(Time will be discussed at Driver's meeting).
I'm open to comments and constructive criticism. I am the one in charge of this event for 2011 but it is most definitely going to be a TEAM effort to make it run smoothly. If there are issues and you are not a part of the solution, then you are part of the problem.
And As I said above, volunteers are definitely appreciated and will help this go as smooth as possible. Thanks.
1.Youth class
2.stock class
3. modified class
4.open class
Rules.
1. Youth..
2. Stock Class.
STRUCTURE....
A.49cc-174cc
B.175cc-250cc
D.250cc 2 stroke
2 -Stock.
-Trikes only
-No wheelie bars
3. Modified class.
-OEM trikes only
-NO ALKY or NITROUS
4.open class.
- Trikes only
-Tires,any tires
NOTE:
