Forum member ps2fixer has thrown the idea around of reproducing various ATC wiring harnesses and is searching for those of you who would be interested in potentially purchasing brand new, hand made, wiring harnesses built to factory specifications. You can find a list of the confirmed harnesses for specific machines, a list of potential future harnesses and a price list by checking out this article.
After successfully reproducing Honda 350X headlight sockets (purchasable here), ps2fixer is now offering brand new reproduced wiring harnesses for certain machines. Below you'll find what is being offered and their respective prices.
________________________________________________
Color Key:
Green = Reproduced 100% using brand new parts
Red = Requires a donor harness to use the plastic shell of connector(s) that cannot be sourced brand new
ATC90/US90 All Years Wire Harness - Based on research, all of the 90cc Honda 3 wheelers used the same harness, can anyone validate?
ATC110 1979-1980 Wire Harness
ATC110 1981 Wire Harness - Can't locate quality photos, could someone post/pm ps2fixer some of the connector ends? He is 95% sure he can make them based on other years.
ATC110 1982 Wire Harness - Have not attempted to locate new frame grommets yet
ATC110 1983 Wire Harness - Have not attempted to locate new frame grommets yet
ATC110 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC110 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC125M 1986-1987 Wire Harness - Couldn't see inside the black rubber boot very well, could use photos of that area to validate
ATC185S 1980-1981 + ATC200 1981 Wire Harness
ATC185S 1982 + ATC200 1982 Wire Harness
ATC185S 1983 + ATC200 1983 Wire Harness
ATC200 1981 Wire Harness - See ATC185S 1980-1981
ATC200 1982 Wire Harness - See ATC185S 1982
ATC200 1983 Wire Harness - See ATC185S 1983
ATC200E 1982 Wire Harness
ATC200E 1983 Wire Harness
ATC200M 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs - There are 3 part numbers for this year, not sure why, one interchanges with 85
ATC200M 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs - There are 2 part numbers for this year, one interchanges with 84
ATC200ES 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200S 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200S 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs - There is 2 part numbers for this year, maybe the 2 plug CDI was introduced this year, if so it should be the same as an 86.
ATC200S 1986 Wire Harness - Must have 2 plug CDI (4+2)
ATC200X 1983 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200X 1984-1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC200X 1986 Wire Harness
ATC200X 1987 Wire Harness - Can't locate quality photos, could someone post/pm me some of the connector ends?
ATC250ES 1985 Wire Harness - Unable to locate new pulser connectors and 6 pin round CDI Plugs
ATC250ES 1986 Wire Harness - Unable to locate new pulser connectors
ATC250ES 1987 Wire Harness - Unable to locate new pulser connectors
ATC250R 1982 Wire Harness (should fit 81) - Built, posted in classifieds section - $75
ATC250R 1983 Wire Harness
ATC250R 1984 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC250R 1985 Wire Harness - Unable to locate new 6 pin round CDI Plugs
ATC250R 1986 Wire Harness - Haven't calculated cost yet (check and make sure you have the 4+2 cdi connectors).
ATC250SX 1985 Wire Harness - Unable to locate new pulser connectors and 6 pin round CDI Plugs
ATC250SX 1986-1987 Wire Harness - Unable to locate new pulser connectors
ATC350X 1985-1986 Wire Harness - $75.
Other Harness Type Parts:
'85-'87 250ES Big Red Headlight Sub Wire Harness - Estimated cost -$25
'85-'87 250ES Big Red Long Headlight Wire - I can source the connector ends, haven't looked into a strong rubber protector like oem has.
'85-'87 250SX Headlight Sub Wire Harness - Estimated cost - $25
'84 200ES Big Red Keyed Ignition - ignition switch sourced from china, fairly good quality, except the wire is a bit small - $20 or for $35 and I'll replace the wire with good quality wire.
ATC350X 1985-1986 Headlight Socket Pig Tails - $75 per pair.
Options for wire covering/appearance:
- Standard PCV tubing
- Vinyl tape wrap
- High Gloss PCV tubing
- Expandable Mesh tubing (none on hand)
Potential Future Reproductions:
ATC70 Headlight/Taillight Wire Kit
Lifan Harness for 70/90/110/125, or Adapters
Suggestions and ideas are welcome. He is also interested in potentially building adapters to make new harnesses using newer parts.
You can reach ps2fixer and place your order by following this link.
